lurgan liar
Jimmy Page XXVIII
Ok ... I'm still new to this...but i've learned a lot in the last few weeks from this forum
My main problem area is The mixing down process...
I understand that diffferent instruments should own a particular sonic space ...and that EQ has the role of thinning particular areas of the audio bandwidth in order to make instruments more easily identifiable when placed in the mix...
Ok, what I now need to know is....Is there a standard procedure involved during the mixing process that can be applied to all instruments placed within a mix...
For example...My song has the following tracks:
an acoustic guitar
bass guitar
kick drum
snare drum
overheads
electric guitar 1 (mild distortion)
electric guitar 2 (overdriven guitar solo)
Vocals
Backing Vocals
Which ones do i record in Mono? Which ones do i do double layers of and pan?
Do I add reverb to individual tracks or to an aux bus?
Panning instruments - what works best for what instruments?
I've heard a lot of talk about Compression...I know what it is ... but where should it be used and where not?
Is there a particular rule about the order in which EQ, Reverb, Compression, Limiting should be applied? I've also heard that dithering should be applied after Limiting...What exactly is Dithering?
Ok I'm gonna stop here because I know that once I can get the hang of this process I'll probably want to start a new thread about Mastering...and that will probably be as long as this one...
Any advice at all would be helpful...ALL i really want to know is the order in which these plug ins should be applied ...And what EQ cuts/boosts work for what instrument?
Thanks in advance
an acoustic guitar
bass guitar
kick drum
snare drum
overheads
Vocals
Backing Vocals
Thanks in advance
