A serious question!!
  • Thread starter Thread starter NOOB101
N
NOOB101
i use Cubase LE 4 and for a while now..i been getting this really annoying pop up
and it says
"The project contains events that use the same audio material as the event in this editor! Press "New Version" if processing should apply only to the editor event!"
and this only happens when I go deep in an audio track and I try to, for example, Silence a frequency wave really small. That message will pop up..and then if i press continue..it will do the act..but right away my computer will freeze after doing another thing. Or if i press new version..it will just freeze.
So does anyone know What the the problem is? and how to fix it?
thank you
(im not spamming!)
Clean up your harddrive and all the temp folders Cubase is using for your sessions. If it doesn't clear up, contact Cubase and find out why it's doing that. There may be a software glitch they don't know about.
