There is a better way to "humanise" drum tracks if that's what you're going for. Find a breakbeat (drum solo) that has the general feel, ReCycle it, and export the MIDI (or use something like the Hitpoints feature in Cubase). In your sequencer, load the MIDI file that you created in ReCycle and extract the groove from it, (in Cubase, Advanced Quantize->Part to Groove). Apply the newly created quantize template to your programmed track. Of course, after this you'll still need to play around with velocity to get it just right.
Personally, I do Industrial and DnB. In Industrial, it's all about machinelike quantization, so I don't even bother. In fact having the drums right on the grid is desirable. When doing DnB, I use a combination of chopped/rearranged breaks and programmed drums, which are quantized to the original breakbeat to get that groove.
