coloradojay
I am starting to research getting some real monitors in my humble ghetto studio. Originally, it made sense to me that bi-amplified monitors were adventageous, since the amps where made for the speakers and, each speaker had it's own amp, so it seemed like the best way to get good flat frequency response (which is a debatable statement, but made enough sense to me).
In my jam space we are using the same home receiver
bose 101s
and radio shack subwoofer
, for monitoring, and vocal PA through the board. Needless to say this setup is less than ideal for monitoring, and also with all of the Guitar and Bass amps we've accumulated now, the Vox are totally drowned out. So now a small amp and PA speakers are on my short list of needs now too (right behind monitors).
The question- is there a good amp out there that I could use to run some low-end monitors (like the alesis 1s or event passives), and also has enough balls use alternately for running some small PA speakers like some JBL 12s. I'm thinkin maybe that I could "kill two birds with one windshield" on my limited gear budget, and be half way to a new PA solution, if there is a suitable amp.
Is that just a bad idea? Should I stick with the original plan of going with active monitors, and then get a seperate rack amp for small PA application. Are the amps that are good enough for monitoring generally more fragile then ones designed for live sound?
Thanks in advance for any advice you can lend.
