A disillusioned VJ observation
  • Thread starter Thread starter notCardio
N
notCardio
I walk the line
I've got a bone to pick with you guys.
I've still got a VJ head in the box, untested, 'cause I don't have a cab.
So I go to the GC that has the VJ cab (1-12")in stock to demo it.
That thing is freakin' loud!
I'm gonna call the local amp guys to see what I can do, but I just thought I should tell somebody.
Grrrr!:mad:
Yeah, you're definitely not going to be having a conversation with someone with that thing blaring. 5 class A watts through a 1x12 is going to be pretty loud, still better than an AC30 at full tilt, but loud none-the-less.
that's not what I was lead to believe.
What were you led to believe? IIRC, a tenfold increase in power yields a doubling in volume, so a 5 watt amp should be half as loud as a 50 watt one.
If you look at the speaker efficiency, that decibel rating is 1 watt at 1 meter. So an efficiency of 90db will put out 90db spl being fed 1 watt at a distance of 1 meter.
So a 50 watt amp will put out, hmmm, lemme see.... 4500 dB. Yeah, that sounds about right. ;^)
No, it doesn't work like that. The watt/db spl relationship is not linear. (obviously)
So are there any
good sounding speakers that are so grossly inefficient as to significantly cut the volume on this thing?
Any good 1 watt/ half watt amps that don't cost an arm and a leg?
Have you considered some type of power soak?
Yeah, I've asked about those repeatedly. The VJ was supposed to be something I would not need one on, though.
If I were going to use a power soak/brake/attenuator thing, then I would just use it on my Vibro Champ, maybe get a Marshall or Mesa head, too.
I still feel like it is soft enough that you could easily put a bunch of blankets on the speaker and it wouldn't wake anyone up but I don't know your situation.
Tell ya' what ..... since I was one of the guys that told you it was soft and since you bought it back when they were $99, if it's unusable for you, I'll take it off your hands. I wouldn't mind having one to mod.
There, hows that? You can't beat that for taking care of your concerns!
Just PM me if that's what you decide to do and I'll get the money together forthwith.
