Chris Tondreau
Member
Okay, I've upgraded to SX and bought a Delta 1010.  Two things I can't figure out....
When you fire up the ASIO setup application, you can enable "Delta 1010 multitrack" (which is what I currently have enabled), or you can chose from something like "Delta 1/2; Delta 3/4".... etc. Is there any advantage to selecting/enabling each individual pair of inputs as opposed to, or even in addition to the Delta multitrack setting?
How can I find out what the current latency is at? In VST, it was in the control panel under the Audio menu.
Thanks!
Chris
Thanks!
Chris
