Slackmaster2K
Gone
Mike, just thought I'd spill a blurb about your computer needs. If the computer is going to be your primary source for recording, and it's not getting the job done...then you're *basically* going to have to upgrade the whole dern thing.
As is most likely the case, the only CPU upgrade you can do is to a faster Pentium. Since the P233 is nearing the high end, I doubt it would be worth your money to go faster there.
To upgrade to a PII you'd need a new motherboard....and your memory will *probably* be out of date (some late model Pentium machines used SDRAM that *might* be good enough to run in a Celeron system...but not a PII...).
If you were to do a major upgrade like this, your hard drive would suddenly become the weak link. One of the fast new 7200RPM's would be in order.
Basically all you can use in an upgrade, if you find that your current system is just too slow, is the case & PS (maybe) and some cards like video and the SB Live you mentioned.
Yer looking at $500 minimum
Since that'd set you back considerably, I'll mention n-Track as a great multitracker for a tight budget. As far as I'm concerned it can do everything! Too bad I don't do everything
http://www.fasoft.com
Good luck!
(And BTW, if you're going to sink money into a new computer, you might want to look at midi/drum software solutions...it could save you some cash!)
Slackmaster 2000
Good luck!
Slackmaster 2000
