Toki987
Rock Steady
Is there a way to quantize at 64th note or 64th triplet in Sonar XL? There is some percussion I need to sit on the tip. I need some tinier pulls than 32 triplet without having to "micro edit" each note.
James Argo said:
Original song : 100 bars on tempo 80.
Then fit all tracks to 200 bars on tempo 160.
By doing this, you can make quantize 32th to feel like 64.
After that, fit the 200 bars back to 100, and pull the tempo back to 80. Import the result to original -audio contains- project. Did it help ?[/QUOTE
I haven`t done it yet, but it does make sense. Halving the bar length, a 32 step would become a 64. I`ll rename a copy and try it on that. It sounds like a pioneer idea if it works.
James Argo said:Too bad, Cakewalk/Sonar doesn't have quantize to 64th. But if you need to quantize to this value, you can modify the way you do the song. By quntizing, I assume you do MIDI things, right ? then if there's no audio track (yet), you can double the tempo. Then you fit all tracks to double spaced it's original. If there's audio tracks, export all MIDI tracks to new project to do this. Hmm... lets say :
After that, fit the 200 bars back to 100, and pull the tempo back to 80. Import the result to original -audio contains- project. Did it help ?![]()
