Actually, I only need one available slot at this stage because the eventual planned front end would be a Mackie Onyx mixer delivering 16 channels of fire wire; the Shuttle has a fire wire port right on the motherboard. So ultimately I would not require even one PCI slot.
The Shuttle has one real advantage in doing on location recording: It's half the size of a conventional tower. You can put a handle right on top and carry like a lunch box. Pic below.
My video uses one other slot, which is AGP. That's it for slots.
Sorry I wasn't clear about tracking as my thoughts were moving faster than my fingers. Or the other way around.
Anyway,
right now my front end is
an AKAI DPS 16 multitracking recorder; a very clean dedicated unit used in conjunction with a live mixer.
In the past I have sent a stereo digital signal from the DPS16 to my SBLive sound card; the Delta 66 will also accept the same thing plus four analog signals.
The DPS16 will let me track at once any combination of up to 8 analog feeds from my live mixer (presently
a Mackie CFX12), at 16 or 24 bit, 44.1 - 48 mHz, without reducing any resources. I've been using it to record a local rockabilly band when I do their live sound.
I'd like to be able to take that whole capability to the next level - skip the intermediate step - straight from the mixer to the computer. Probably the most stable tracking combination would end up being 24/44.1 or 24/48 until I upgrade the mixer.
The eventual mixer upgrade would give me fire wire from 16 Onyx preamps right to the Shuttle motherboard - bypass the soundcard. That's why I want horsepower. It would also be a good time for me to move up the food chain to learn Cubase.
Anyway, that's the plan. Once I have a reliable 16 channel front end as wel as horses under the hood, I'll be busy for the near term and can begin to do some subtle live tracking I've been itching to get into.
