C
clevodrummer
Tascammer
The manual says to keep it up from peaking out around 6db, everything else I read says around -0- db for universal applications.
Is it normal for the meters to run lower at playback than where they were when I recorded them?
When I record a bass guitar and try to keep it at 0+ up to six it shows lower levels at playback.
Im not sure if I should trim it even higher during recording so playback levels are higher.
Im running the bass guitar through a POD at tube preamp/compression setting. Im thinking I should record with levels closer to 6db at all times.
I need to get an idea so I can get off the ground with good info as far as level settings.
I figured I better get an answer to this question before I even think about the drum mix.
Thanks.
"better to ask now than later"
Thanks.
