4 channel 1/4" reel to reel deck recommendations
  • Thread starter Thread starter garyrice
G
garyrice
I'm interested in purchasing a tape deck (see my title). I've identified 2 models that seem to have the features I want:
TEAC A-3440
Tascam 34B
Features that I want:
-10-1/2" reel capacity
-ability to record or play back any/all channels selectively
-good track record for reliability
-repair parts available
What other decks should I consider looking at?
Gary
I'd generally prefer the 34B vs the A-3440, because it's newer. You may get better size/weight comparison and lower noise specs with the 34B, also because it's newer, but in this game condition is everything and can vary a lot unit-to-unit. Parts would be more available for the 34B, but you may be on the second hand market for parts on both units. They're both considerably obsolete. Tascam Corp. would have simpler and more common parts for both. Complex and higher value parts you may be scratching dirt.
There is also the "std" Tascam 34, which is straight line level I/O, without the external mic inputs and onboard headphone monitor of the 34B. Based on these design upgrades, the 34B can be a little more versatile in the field, as is.
Is there any reason you want to go with 4-track vs 8? The Tascam 38 can give a boost in production value at a price boost on 1/2" tape, but the Fostex E-8 is a 1/4"-15ips-10.5" reel 8 track that might not be bad if you can find one in good condition. Keep in mind the narrow track width of 1/4"-8-track will also affect the fidelity specs, which is where 1/4"-4-track will trump it as a format.
4-tracks can be very limiting. I'd not suggest relying too much on track bouncing if you work alone, but working with a group 4-track can be satisfactory, or if you're ok with a very sparse production of your solo efforts.
There is also a Tascam ATR-60/4, which is a lot harder to find, but 4-tracks on 1/2" tape would sound HUGE, also with the price bump.
A good place to start might be a good condition 4-track cassette Portastudio, such as the Tascam 246, unless you're wedded to the idea of 10.5" reels at the outset.
With used equipment condition is everything.
The 3440 is the older of the 2 and has a considerably beefier transport with rebuildable AC motors. The 34B may do faster punch-in/outs and have slightly cleaner electronics.
Thanks for the nice comparisons between the two decks I listed. I think either of them will work for me.
What I REALLY wantwed to know is:
What other decks should I be considering if any?
I specifcally want a 1/4" tape deck since I have a bunch of prerecorded tapes that I want to digitize.
Gary
If all you need is the playback function, the earlier TEAC 3340/3340A models and the Tascam 40-4 are also good candidates. Sony, and Akai also made 1/4 inch 4-tracks but they sold in fewer numbers making them harder to find and harder to service. Of all the machines I've mentioned, the 40-4 is the built the best.
You will have to consider the speed at which the prerecorded tape were created.
A 1/4", 2-channel/4-track would be thought of as a consumer deck. There are many more choices in that regard.
Look for a TEAC X-10, TEAC-1000, TEAC-2000, and many others, if you need 3.75 ips/7.5 ips.
If your tapes are 7.5 ips, then a Tascam 34, A-3340, 40-4 type-thing would suffice. These will also do 15 ips.
Many others from different mfgr's, Technics, Akai, Sony,... will be "consumer" decks.
:spank::eek:;)
Have you considered bringing them to a studio and have them transfer the tapes to CD? If all you want to do is this, then it may be more economical for you. I would be happy to offer you my services, but I'm currently looking for replacement heads for my A 3440. Do you need 4 tracks or two?
