M
Mr Music
1. Can i made a bass trap 4 inch thick, 8 feet high and 2 feet wide
RATHER THAN 4 feet high and 2 feet wide which is the standard?
http://www.hp-h.com/p/hapicmpur/basstraps.htm
for example here in step 5: he has 2 traps in the corner...i just want to make one long one that will go from the floor to the ceiling....is that ok?
my ceiling is 8 feet so i wanted to have a single perfect cover fit from the floor to the ceiling...
2. Since 4 inches is better than 2 inches of fiberglass thickness for absorption- can i just have all my bass traps at 4 inches? because i do have enough space...
every 4 inch thick panel filled with fiberglass will have a space behind it...the corner panel...the ceiling panel and the flat wall panels...
basicly, whats the point in going for 2 inches in width when im able to do better with 4 inches...
3. I am not able to take off the carpet that i currently have in my room...is the "put some plywood beneath the area youre recording in" really a need? But other than that i have no other choice i guess..
THANK YOU SO MUCH!
THANK YOU SO MUCH!
