T
The_Raven
Howyadoin,
Picked up the new Sound Forge and was checking out the 24-bit goodness, but I ran into a bad feedback problem. Levels were OK until a signal came into a mic, then the level went up and stayed at wherever it peaked. If another, stronger signal came in, it would boost the peak and again stay there... If I reset the record monitor there would be no effect, but if I turned the checkbox for monitor off then back on, the levels would return to normal, but would start freaking out again upon an input to the mic. Note that this does not happen in 16-bit sampling, only 24-bit... any ideas?
Thanks!
-Mark Pags
Sherbet Studios
Thanks!
-Mark Pags
Sherbet Studios
