Z
ZioGuido
Ok, this may be a dumb question, but... Well, I own 2 Revox A77, a Mark I dated 1969 and a Mark III dated 1972, they're both 2 tracks at 3-3/4 & 7-1/2 IPS and they're both in great shape, so they're basically the same machine. I can record a tape on one and play it back on the other one, swap tapes all the time without ever noticing any difference, either by ear and by instrumentation (scope and fft).
Recently I acquired an AKAI GX-210D, I got it cheap because it needed some attention. It's a 4-track deck with auto reverse, but unfortunately the reverse function can't be used because the solenoid that moves the floating head seems too weak for doing its job (the deck is dated 1975).
If I play back on the Akai a tape recorded on the A77 it sounds dull with prevalence of amplitude on the left channel; and if I play back on the A77 a tape recorded on the Akai it sounds way more duller. Now it's evident that their heads don't have the same alignment.
Since the auto-reverse is unusable, I thought to block the floating head and re-align the heads on the Akai so to make it compatible with the Revox. Mission accomplished as far the playback is concerned. But there's something wrong with the recording. When I try to overwrite a tape with the Akai and play it back on the Revox, I can still hear what was recorded behind.
And now my question: is there a relevant difference in the 'pitch' (or width) of the recordable tracks on the two decks? I came up with the conclusion that the tracks recorded by the Revox are wider than those recorded by the Akai. Because of this, when the Akai deletes the two tracks, it only 'digs' in the middle of the tracks, while the Revox is still able to read their edges.
Is this correct? And if the answer is yes, this means that there is no way to make the two decks compatible? And does this apply to all other 4-track decks?
Guido.
Guido.
