ausrock said:
Ed,
Thank You. That is about the most clear and concise explanation I have come across.
You may care to advise on the following:
Console Tape Sends (Direct Outs)......-10dBV.......this can be changed on the channel pcb's to +4
PreSonus Comp......-10dBV / +4dBu...............switchable
Fostex D160 Recorder......-10dBV
Yamaha REV5......-20 / +4dBm...............switchable
Digitech Effects......+4dBu
OK, I'm getting confused by 1; dBV/dBm/dBu........are they all basically one and the same?
2; The REV5's nominal levels don't give me a -10 option.
Instinct tells me to run anything I can at -10, the REV5 at ??? and obviously the Digitech is stuck at +4. If I set the REV5 at -20 I guess I will just have to watch how much signal I feed off the Aux Sends, otherwise set it to +4 and wind the fuck out of the Aux Sends
regards,
Chris O
First off, I know of no way that a patchbay can change the operating level of ANY audio device. This is not possible because that audio devices operating level is set by the OP Amp on it's I/O's.
Second. Ahhhhhh...Yamaha and their very weird -20!!! Treat that like you would -10 if you need to make a -10 connection.
Next. Yes, it sound like since your recording machine is running at -10, you will want to set your outboard preamps to -10.
Now, with your Yamaha, you possibly could set it to +4 IF the consoles Aux or Effect sends are +4. Get it?
The idea is make sure that ANY connection you MIGHT make that both the output of one device and the input of the other device are at the same operating level. It is really that simple. Operating levels and "balanced/unbalanced" are two different things in most cases. Sometimes, a device I/O might only work with a certain operating level, like the balanced I/O might ONLY be +4 and the unbalanced I/O might only be -10 and they won't have a way to change that. Other devices, like a lot of Behringer gear, allow you set switch the operating level via a switch, and setting it to either -10 or +4 set's it on both balanced and unbalanced I/O's on the unit.
I can't think of any more clear of a way to explain it all. Sometimes, to get the right match up's you might have to purchase XLR to TRS connectors and what not to make the proper connections.
It is a good idea to read your manuals thoroughly for their explainations about what operating levels are on each of it's I/O's.
Ed
