evm1024
I picked up a set of 2 older 1/2" MRL tapes off of ebay the other day (for $15) figuring that if nothing else that the reels would be worth that. They arrived tonight and are both sticky (as expected). They are in the "oven" right now baking.
One is from 1975 and the other from 1984. The older is 200 nW/m and the newer is 250 nW/m. Only one has a color dot and appears to be Ampex 406. The older MAY also be 406....
They are 7.5 ips NAB tapes. Now at first glance this appears to be a problem but reading through "Choosing and Using MRL Calibration Tapes for Audio Tape Recorder Standardization" http://home.flash.net/~mrltapes/choo&u.pdf we find tables "5-7 Calibration Tape: 7.5 in/s, NAB (IEC2) Equalization
Desired Playback: 15 in/s, NAB (IEC2) Equalization" and "5-4 Calibration Tape: 15 in/s, NAB (IEC2) EqualizationDesired Playback: 15 in/s, IEC (IEC1) Equalization" which give us the correction factors for the speed and EQ mismatch.
I plugged the corrections into a spreadsheet and came up with this table:
7.5 15 7.5 Speed 15 EQ 15 Output
NAB correct NAB correct IEC1 mV
31.5 63 -10 2.25 -7.75 2.31 -5.44 0.090
63 126 -10 0.45 -9.55 0.83 -8.72 0.042
125 250 -10 -0.55 -10.55 0.35 -10.2 0.030
250 500 -10 -0.84 -10.84 0.18 -10.66 0.027
500 1000 -10 -0.71 -10.71 0 -10.71 0.027
1000 2000 -10 0 -10 -0.48 -10.48 0.028
2000 4000 -10 1.63 -8.37 -1.43 -9.8 0.033
4000 8000 -10 3.48 -6.52 -2.33 -8.85 0.041
8000 16000 -10 4.51 -5.49 -2.74 -8.23 0.047
10000 20000 -10 4.67 -5.33 -2.79 -8.12 0.049
1000 2000 0 0 0 -0.48 -0.48 0.283
7.5 --- Freq at 7.5 ips
15 --- Freq when played at 15 ips
7.5 NAB --- Level recorded on MRL tape
Speed correction --- dB correction when played at 15 ips
15 NAB --- VU when played at 15 ips NAB Eq
EQ correction --- dB correction to get IEC1
15 IEC1 --- VU when played at 15ips IEC1 Eq
Output mV --- Output voltage (where 0 VU = 0.316 mV)
I've not put in a correction to recalibrate at a different fluxivity but that is a straight change based on table 4 in the paper.
Regards, Ethan
PS sorry about the sucky formatting. I've added it in as a word doc.
Regards, Ethan
