badassmak
Herbi-Whore
It has been many moons since I posted here, happy to see this forum still around~!
Be forwarned, this post is about accordion micing in live situations.
I have tried a few different setups now, and still can't find a 'thing' that works.
I play in a very loud folk punk outfit and am having trouble keeping up with the volume.
At this point I have discovered the best method to be an SM58 capsule glued inside the box and wired to a 1/4" out which I then use with a rather inexpensive wireless guitar to send the signal to my amp/speaker. I have tried much more expensive omni/condenser mics specifically designed for accordions but have found they feedback like crazy when I try to turn them up to a useable volume. The only problem with the 58 approach is the fact that I have to turn the gain up so high it creates a tremendous amount of 'hiss', and the volume is barely useable with a good chance for feedback...still better than the condensers though! I am also using a Triton Fethead in my setup to help boost the signal but it is still not enough.
So now I have had this thought about installing a second 58 capsule inside the accordion - maybe then I could reduce the gain substantially and retain volume?
Initially I thought to wire the two mics together onto a single circuit but it seems to me this will leave me with the same issue, just better rounding of sound due to mic placement (eg with this I can also get better representation of sound of the entire accordion as opposed to the one mic setup where the notes closest to the mic have more volume). Am i right in thinking this? If so, would I have the ability to somehow sum the circuits into one signal without loss of gain? Does this make sense?
Also - any better suggestions? I guess ideally I might also try any dynamic with a high level of sensitivity, higher than the 58's and see if that would work, but am also having trouble finding out what those actually are.
Many thanks!
Many thanks!
