Appreciate any feedback/tips re- pan position of individual tracks for mixdown...i.e.
How wide a stereo field do you set up...?
How many tracks are center panned...?
When an instrumental part is on 2 tracks instead of 1 what type of pan position do you use....hard L/R or somewhere between that and center....?
Also in terms of having either a stereo mix copied back to 2 tracks or a stereo bounce on 2 tracks,
what type of positioning do you use when adding this to the final mixdown...?
I'm using a Tascam DP-008ex but any similar recording situation is applicable(i.e.either mono tracks or a submix made from mono tracks mixed down to stereo then copied back to 2 tracks from the stereo master-been using this approach to set up the drum track like a drum buss)
In addition interested in any info re- how using reverb factors into the stereo field produced ....
