yeah. so a compressor generates a lot of heat during operation which means it needs to have plenty of air space to keep it alive. so from an engineering stand point its going to need air flow which unfortunately also means sound flow. If one was to insulate one to reduce noise it would shorten the life, the more insulation the more it would reduce the lifespan.
Funny story about refrigerators and their noises....
One of my fridges (and it's funny that it's the newer one, not the older one...probably 15 or more years older!!!) about 5 years ago developed a small "clang" when the compressor would shut off.
I deforested it for two days, to make sure it wasn't some ice on a fan blade...and pulled it out from the wall, opened the back cover, didn't see anything out of place.
So I called in the service guy (this was a Sears Kenmore)...and he shows up, and I meet him outside just as he's getting out of his van, and he asks what's the problem. As soon as I say there's this "clang" that started happening on shut off....he just smiled.
He says to me...I can tell you exactly what it is without even going into your house...he says one of the rubber bushings inside the compressor that acts as a isolator, has worn out...so you get some metal-on-metal contact when it shuts off sometimes and there's that momentary shake.
He shows me on a dead compressor he had on in his van...he hits it, and you here some "clang".
He said...to replace the compressor would cost more than buying a new fridge (this wasn't one of those ultra-expensive models)...or he said, you can just ignore it, and the fridge might run for another 10 years, or eventually another bushing will go, and then it will get serious noisy...but there was nothing to fear...no fire or anything dangerous, just the noise.
So...here it is...5 years later, and it still works just fine, and the "clang" has even gotten quieter lately, and I don't even notice when it shuts off anymore...so I'll wait another 5 years and see if it's still running.
Speaking about the "ultra-expensive refrigerators some people buy...
...like those Sub-Zeros (or whatever they are called) that cost $3k+...or even more...
...my sister had one, musta broke down twice, they replaced it, and the new one broke down also.
A friend of my had another brand that she spent over $3k for...with the fancy doors and lights...she had the repair guy over at least 5 times that she told me about, he replaced all kinds of parts...and she ended up tossing it and buying a different one.
So any old basic fridge for $500 can do just fine.
