WhinyLittleRunt
Member
I'm building an XLR patch panel on the wall under my studio window that will connect to the back of my console (er, Tascam 388). I got a very nice panel off the auction site that was all Switchcraft female connectors and just needed to be cleaned up. I then bought the twist-type Switchcraft male connectors which would run from the back of the panel into the console.
As far as cable goes, I am using some cable that I salvaged from a Neotek Series 1 recording console that we got into my buddy's studio a while back. I really saw no need to buy cable when this was used for the same purpose. There were three different types of cable, some were shielded, some were not. I did a test with the un-shielded gray cable as an instrument cable (just for giggles) to see what kind of noise it would pick up. Well, it amplifies every little thing it touches or hits. Pretty much expected that. But in the application I'm going to use it for, I didn't think that would be an issue. Plus, the grey cable was more abundant so that I could keep my runs even and long enough to reach the console with room to give but not too long (prob 2 ft approx.) So I soldered one cable and tested my patch panel. My test was going direct into my Yamaha HS50 monitor. Before plugging anything in there was a constant buzz. When I connected a mic, buzz went away and all was happy.
So here's my question -
1. Is unshielded cable ok to use in this application if it isn't being moved? Will it pick up interference from the other cables?
2. Was using an active monitor to test with not really a good test? I have my Tascam packed up at the moment so that was all I had available with a balanced input and power...
3. Would shielded cable just be overall smarter to use? I really didn't want to spend any more money on this stuff since we had such an overabundance of cable left, but if worst came to worst I could probably pull out matching lengths of shielded cables.
