squibble94
Nature of Force
Hey guys, I'm not sure if this is common or not, but I found an easy way to make a clean hole in a kick drum's resonant head. Basically, you find an aluminum can the size you want the hole to be, then empty it (obviously). After that, heat the rim of the can on the stove. Pick it up with oven mits, then firmly press it on the head where you want the hole to be. After that, the hole should pop right out.
As I said, I don't know how common this is, so I might sound incredibly stupid right now.
