B
		benherron.rrr
Hey,
I bought a new computer running windows 7, Im running cubase 5 32bit, connected to a toneport UX2 where my monitors are connected to the anologue outs, A casio digital piano which I use as my MIDI keyboard and a beringer BCF 2000 which I am using as My MIDI controller.
Its a Dell computer, fairly well kitted out.
I would like to know how I can optimize the computer for audio work. not in a sence of what plugins/vst's and mics I should buy. but the general set up of the computer.
One of the biggest problems I have been having is with latency. I have posted about this in another thread, but could do with a little more general help.
Latency with audio playback is absolutly fine, but it's the latency Im getting with my MIDI, running the settings at 24 bit, 512 sample rate. im getting input latency at around 18ms and output latency at around 24. If I lower the settings I get 6ms but thats still quite large. It is quite an important thing as I use kontakts alacias keys to record all my piano work. so low latency is a nessesity to playing piano correctly. In the toneports settings there is a slider with about 6 settings for the buffer (if you slide it down you get lower latency with increased cpu usage.) If i slide it right down to the bottom I get no sond what so ever.
I also find that when Im in cubase and have just one instance of kontakt the asio time usage is alot higher than it should be and I begin to get clipping noise (not from peaking) considering I never had this on my laptop with 1/3rd the power capacity. I also get the same result when having just a few audio tracks with no plugins on them. again It took quite alot to do this on my laptop which is also a dell. I bought this computer to erradicate these limitations, but they seem to be worse.
I have no internet connected to the computer appart from a wireless adapter I got so I can get updates etc.
by the way I have updated all the drivers and softwear to date, and had a long look around the line 6 website which ended up being useless help
Does anyone have any ideas that could help me? and also any settings changes I can make to truly optimize my computer?
