Hi, I have recently been learning the tascam SX-1 and am trying to setup some connections.
I have a Tascam DA-88 and want to send the 8 RCA unbalanced inputs to the SX-1 over TDIF. I also have a stand alone mixing board with phantom power. I don't think the DA-88 has Phantom Power.
If I hooked up a Condenser mic to one of the RCA inputs or even a standard dynamic mic. How much trouble is it going to cause that the RCA inputs are unbalanced? How will phantom power work out, or will it just plain not work?
I could have the mics go into the standalone mixer for phantom power then into the DA-88 then into the SX-1. Or I could run the Mics into the DA-88 and then into the SX-1 and assign phantom power there. I just need to know if those unbalanced RCA inputs will make both of these scenarios impossible.
What do you think?
Thanks,
Mongoo
P.S. does anyone know if live signals can be routed through the DA-88 to the SX-1 via TDIF in real time or do you have to record and then play back to output to TDIF?
Thanks Again
What do you think?
Thanks,
Mongoo
Thanks Again
