ENIGMACODE
Hello to ALL!
I've posted here before, and everyone has been really great in offering advice, and information in regard to 'Home-Built' Studios ........ where else can you get soooo much GOOD RESEARCHED DATA?!
After participating in so many discussions, I've come to realize that while there has been so much good advice, many times questions about specific issues lead the Home Builder on a never-ending, impossible quest to meet his meager accomplishment.
I suppose I should trust my own building skills, and proceed without further haste to build my simple 'all purpose recording recording room' ???
BUT
I would LOVE to first wrap up some inquisitive loose ends, and get the final blessing from the Big Guys out here ......... or am I asking for another punishment? kidding
Uploaded JPG Drawings:
My diagrams have not been drawn to the accuracy of some others - BUT hopefully they will do ......
I will start with this overview:
Please bear in mind that this construction project is for the purpose of creating one 'all-purpose' irregularly shaped recording/rehearsal room to be built within the basement of a tiny 2-bedroom row home - IT'S ONLY A HOBBY .....
http://locationstudio.net/new.jpg
My main concern will be 'Reflection', and secondarily 'Isolation'
The Floor:
I've already laid down (hammer gunned), pressure-treated 2X6's on leveled concrete, and 3/4" Plywood will follow - screwed and glued to the runners as a sub floor.
Parallel Walls:
I understand the importance of NON- PARALLEL walls, and perhaps I can incorporate a few .....
Saving Money from Expensive Auralex Products:
I'd like to SAVE money in regard to building my own bass traps, and line the walls with some type of FOAM covered with fabric (further details below)
http://locationstudio.net/in-wall.jpg
Ventilation:
You may see that the only type of ventilation is from an Air Conditioner that will unfortunately pierce through a 2 wall constructed outside wall - but it will have a Removable Sound Barrier Cover used during the winter months ......
Remaining Questions holding up Construction:
I still have some questions which are preventing me from continuing construction - they should not be difficult to answer:
Gasket Material:
I planned on laying 2X4 wall plates down on the floor, with gaskets between them, and the 3/4" Plywood Sub floor. I'd like to use this same gasket material, also as an insulator where the Ceiling Joists are fastened to the top of the walls.
(any ideas on where or what to use for gasket material?)
Inner Wall Construction:
I planned on facing the Inner Walls with some type of foam or fiber insulation (for reflection), (details below).
With this in mind, what type of wallboard should I use?
5/8" Drywall - 1/2" Drywall - Homasote?
Inner Wall Treatment:
(Studio Side) - I've read where some guys have had luck in applying a product called 703 (ceiling tiles), with the vinyl layer peeled off, or some other type of Fiberglass or Foam attached directly to the Inner Walls, then covered with a fabric and framed with 1x3's
Here are a few photos of a similarly constructed wall:
http://locationstudio.net/live4.jpg
http://locationstudio.net/roland3.jpg
Outside Wall Treatment:
Since this is a room within a room, I'd like to know if I need to have drywall on the other side of some of the newly constructed walls? Hopefully not, so that it will not be necessary for me to stagger the studs ...
http://locationstudio.net/top.jpg
http://locationstudio.net/heater.jpg
Fiberglass Insulation stuffed inside the walls:
Is 3 1/2" of fiberglass insulation in the INNER walls sufficient? And as asked above, is it OK to just simply leave the Outside Walls exposed (leaving the insulation exposed)
Thanks to everyone ……..
Feel Free to email me:
Best Regards
Michael Fraticelli
rocknroll@ucwphilly.rr.com
BUT
The Floor:
Parallel Walls:
Ventilation:
Gasket Material:
Best Regards
Michael Fraticelli
