JimmyS1969
MOODerator
Can't anyone just load Windows on a partition on a mac and use whatever works in any given situation? Just curious.
Can't anyone just load Windows on a partition on a mac and use whatever works in any given situation? Just curious.![]()
Yeah, you can certainly do that. Apple supplied 'boot camp' to make it straight forward.
They also put together driver packs for each MS OS.
I've never used it, but I can see it being popular amongst gamers who use logic, or whatever.
You can. And also do the contrary: it is just to install VMWare on a PC and then put a MacOS. You don't even have to reboot your computer because it will run within Windows. Actually with VMWare you don't even create a partition as it creates a virtual machine with a virtual partition within your existing partition. Anyway, since Macs started to use Intel based CPUs they became PCs tweaked to use Mac OS. LoL! This is the reason why either modern Macs and PCs can run software from each other with small hacks.
Keep it simple - Buy what you like.![]()
I am a Windows guy, but have worked with macs in the past as well. I must say, Mac is much easier if you are just starting out and have no preference.
Most DAWs will work either way. Interfaces work both ways (some have both USB & Firewire). Thunderbolt, BTW, has had a lot of issues with Windows based machines. Firewire, as well has problems unless you get a certified TI card. Best in the Windows environment to stick to USB/PCIe. Mac can use all if they have the ports (some no longer have USB)
Your external equipment, of course, will not be affected.
So, unless you're intent on going with Garage Band or Logic Pro you can use a Windows PC and get the flexibility (and the headaches) of the open architecture. You are likely to spend less, but you might get lesser quality, depending on the builder. Most of us have dedicated PCs for recording and keep them away from internet (for the most part) so we can control upgrades and other such nonsense that slow or corrupt our systems.
Unless you are looking at FLStudio, you can use a Mac and get the structured support of Apple's proprietary hardware and (mostly) trouble free upgrade paths. You may spend a little more, but in the long run, it might be worth a few less headaches.
Happy Recording![]()
Why not go for the best of both worlds, building a Hackintosh! Sheep as a PC, good as a Mac, or even better ;-)
Because I bought the then top-of-the-line Mac, I do not know, for example, how current all-in-one Macs differ in performance (i.e., whether they can cope as well or better, or worse, with latency as my computer).
Generally people want something they can rely on for professional, or even hobby, media.
The main arguments for apple are usually the closed set of hardware that's available, which minimises compatibility issues,
and the sheer simplicity of maintenance which results from that.
Hackintosh is a pretty bad solution for a low maintenance, reliable, studio computer for the average user. Just like linux.
Admittedly the whole setup is a lot more user friendly these days, because a community of dedicated hobbyists have developed automated tools to do most of the work for you, but if you hit an incompatible chipset somewhere along the line you're up shit creek.
There are enough users out there who can't manage to buy compatible hardware for their windows setups, without throwing hackintosh into the mix.
FWIW, I ran osx86 between 10.4.* and the start of 10.9. I don't think I ever recommended it to anyone, though.
I'm aware that I'm not the average user.
Well I have use it the last 6 years for music, and Newer have a fail, or screen of death, that I have TO much in windows.
The thing is I don't upgrade my system as soon it coming a new OS, I wait to every thing works. It is stable like a rock! I use 10.8.5, and Don't gone upgrade.
OK if you own a Studio then I can understand, but if you, like me, a poor home maker who Love to Mix Master, it is Perfect.
Just build it after recommendation on the hardware,
then you safe, and free to upgrade your hardware when you need or want.
To be fair, once it's up and running it's gold. If you don't update anything that bad boy's good for life without any real maintenance.and Never have a fail, or screen of death.
I really would like to believe on it.Well I have use it the last 6 years for music, and Newer have a fail, or screen of death, that I have TO much in windows.
Anyway, all in all a Hackintosh falls in the very same anti-crack philosophy of the forum.
Technically I don't think it does.
It's a breech of Apple's EULA which people interpret in different ways, but you can legally buy a copy of OSX and run it on a PC without using any illegal cracks or patches.
Many hackintosh enthusiasts pride themselves on preparing their machine to accept a vanilla (unaltered) OSX install.
Nothing has been stolen or illegally obtained, which seems to be the main frowned-upon thing.
Now, if you're downloading a pre-patched distro or something that's a different story.
You can buy legally a copy of their OS but it doesn't mean that you are allowed to run it other than on an original Mac.
As far as I can understand when you build a Hackintosh you are 'cracking' a system to accept an OS that supposely shouldn't.
What I mean is: try to put in the market a Hackintosh and wait to see if Apple won't fall over you with all their rage.
