apl
Stand Up Comity
Hey, Harvey, I heard that Leo tried to recruit Les. What do you suppose would've happened to Gibson if the Paul was a Fender?
dgatwood said:Look into it before you go trying to BS me about what is and isn't possible.
sdelsolray said:I did. I told you Schoeps and Gefell mics are made by Elves, dumbass.
dgatwood said:You don't see it, but it's not for the reasons you think. It's very hard to gold sputter a diaphragm in the thicknesses needed. Gefell uses a 0.1 micron thick layer of gold. I'm told that many cheaper capsules have 1 micron of gold or more. That's one big problem with cheap capsules, and is the reason that, for example, Peluso capsules are built in China, but sputtered elsewhere.
Second, while you can fab parts that are remarkably close to an existing part, the tolerances for an "exact" match are fantastically small, so cloning a part is exceedingly difficult---doubly so if you're trying to do it on the cheap---and if you're not trying to do it on the cheap, you're likely to want your capsule to have a bit of its own sound anyway rather than being a perfect clone of someone else's capsule.
Third, while you could build a machine to optimize the tension of mylar, AFAIK, it has never been done. It is conceptually very simple, but the precision involved (due to the small scale of the parts) would make the manufacturing equipment quite expensive to build if you want to get the same quality as a good capsule. The question then becomes whether it would be cost effective to use a machine. In the quantities that boutique mic manufacturers build, the answer is almost definitely no.
There is no technical reason why a human must be involved, though. Any measurement that can be performed by a human can be performed by a machine, and the notion of "intuition" is what we in computers refer to as "expert systems". Look into it before you go trying to BS me about what is and isn't possible.
MCI2424 said:Then there is no reason that a computor can't come up with perfect recordings everytime. Mixing should be done also. Just put up the mics and let the computor set everything including mic placement, eq, compression etc. No reason a human should ever get involved.
Why is a great recording engineer great? Pro tools should eliminate talant completely.
MCI2424 said:"...The New Gefell M9 Capsule
Because PE (Mylar) is readily available, is easier to use, and can be fashioned in to a lighter membrane, it has become the material of choice for all metal-film microphone manufacturers. The lighter PE material provides a more responsive capsule, which results in greater sensitivity and articulation.
But manufacturing PE capsules is not without its challenges. As discussed above, due to the rolling procedure employed during manufacturing process, the molecular structure of PE becomes directional. This means that it has more resilience in the ‘roll’ direction. This prescribes that the capsule cannot be automatically tensioned to a given formula, but must be hand tensioned and ‘tuned’ like a drum skin for optimum performance. Hand tensioning by highly skilled employees is probably the single most important aspect that differentiates ‘the hand-crafted Gefell M9’ versus all others. .."
dgatwood said:Translation: we aren't smart enough to mark an arrow pointing in the direction that the roll came off the conveyor....
I'm just saying....
There's nothing complicated about building an auto-tuner for drum heads, either. Thwack the heads at multiple points, take measurements, do an FFT on each sample to determine the fundamentals at each point on the head, do some math, adjust based on the math, repeat until tuned at the desired pitch. The difference is that nobody bothers building such a device for drums because the cost would be too high and nobody would buy it; few people tune a million drums a day.
