Well, that's cool & all,...
but I don't think the MR8 "takes it up a few notches" from the 424mkIII.
Examples:
> 424mkIII: 8/input- 6/channel-strip- 2/buss mixer- w/4-Direct capablility
> Fostex MR8: 4/input- 2/channel, w/no mixer to speak of.
> 424mkIII: 4-XLR inputs & 8-1/4" inputs, (no phantom power), 8 inputs of which may be used simultaneously. (XLR & 1/4" inputs may not be used on same channel simultaneously).
> MR8: 2-XLR inputs (no phantom power) & 2-1/4" inputs. (The XLR and 1/4" jacks may not be used on the same channel simultaneously).
> 424mkIII: Records 2-simul/max in buss mode, where all 8 inputs can be bussed to 2 tracks. Records 4-simul/max in Direct-mode.
> MR8: 2 inputs-to-2 tracks, 2-simul recording/max.
> 424mkIII: Analog I/O, Line-Outs & Monitor Outs in stereo.
> MR8: Analog Line Outs & USB
> 424mkIII: (2) Effects outputs, one of which doubles as CUE monitor.
> MR8: No effects outputs, but contains effects-button "presets".
> 424mkIII: 6-channels with 3-band EQ, w/mid-sweep.
> Mr8: No EQ to speak of, except EQ-button "presets".
> 424mkIII: Built-in high-function mixer.
> MR8: Requires external mixer for upward (>2) mixing functionality.
> 424mkIII: 15 min/4-track record time w/C-60 cassette, 22.5 min/4-track record time w/C-90. When media is full, just change out to a new cassette & continue.
> MR8: Appx. 3min/8-track record time on standard sized 128mb CF card,... more time allowed if you purchase a bigger CF card, at extra cost. When memory is full, you must dump memory to your 'puter & clear card to continue.
> 424mkIII: functions fully independent of the 'puter.
> MR8: full functionality dependent on the 'puter.
> 424mkIII: Tracks: 4-total.
> MR8: Tracks: 8-total.
> 424mkIII: AC powered, w/12Vdc adapter.
> MR8: Battery or AC-12Vdc adaptor powered.
> 424mkIII: S/N Ratio: Normal Speed: 88db w/dbx (unweighted), High Speed: 90db w/dbx (unweighted).
> MR8: S/N Ratio: 88db (unweighted).
** See friends, this tells a lot about the sound quality, and by these numbers, (S/N Ratio), the 424mkIII "takes it up a notch" on the MR8!!!** Sorry to burst yer bubble, all you MR8 guys!!!
> 424mkIII: Blue!... (although I've seen one from Japan that was black).
> MR8: Red!... (that I've heard is now also offered in black).
So,... make yer own judgments, but in my book, the 424mkIII is a WHOLE LOT MORE RECORDING TECH than the MR8.
I have (2) 424mkIII's, as well as (2) 424mkII's, but I'd not even consider getting the MR8, because (IMO) it's cheap and underpowered. As always, YMMV.
![EEK! :eek: :eek:](/images/smilies/eek.gif)
