The first likely thing to happen is that the 222's inputs will be overloaded! The interface (got one) has an Operating Level of -10dBV (316mV) and I would put a tenner on that mixer delivering +4dBu about 3 times that so you would have buggerall headroom.
The 222 should drive a pair of active monitors but the output is unbalanced. Actually the wee Behryy is quite a good 16 bit DAC for the money...WAY better than any PC soundcard but for recording the 16 bit only word length and low headroom makes them poor company for "pro" gear.
Keep it for tape dubbing duties!
Oh ok! So let me get this straight! I might have 3 options:
1. Using the USB digital interface that my mixer has (I can use 4 chanells), but I'm not sure if I must use the cd to install the drivers. I don't have the cd, since I bought the mixer from someone else, not brand new from store. So do I need the cd to install the drivers? In the manual it says that I must install the drivers, and in the middle of the process I must plug the mixer in the pc, then instert the "cd that was supplied". I'm not really sure...
2. Buying an interface with let's say 9 inputs. If I want to record drums, I mic them up, plug them into 9 channels, and from each chanell go from the channel insert and use it as a direct out, plug the cable going from the insert directly into the input of the interface, and record!
3. Buy an interface with 2 inputs (focusrite 2i2), and use drums on my synth. That's what I would do, since I won't have much time to record live drums.
Ok, so if I got this right, in audio recording, mixers are used just because of the preamps, am I right? Not to record more channels, since you need more channels on your interface as well.
