I just need to know 1 thing. If I plug the uca222 to the mixer, and then the uca to computer, will I be able to record all 16 chanells?
---------- Update ----------
Also, what do you mean by "direct outs"? What are those suppost to do? I think I know what you're talking about but I'm not sure...
Sounds like you want to experiment with recording via an audio interface that has a good converter. I used to have a Zed12FX which I thought was awesome but I didn't like the built-in usb 1.0 which only records 16 bits and records in stereo only. I tried to connect the main XLR outs to another audio interface. The result was ok but not as good as recording thru the audio interface alone. After trying so many different audio interfaces (M-Audio Profire 2626, Focusrite Forte, Presonus 1818 VSL, Steinberg MR816CSX), I landed on the Universal Audio Apollo which I think has the best converter and the lowest latency. It's hard to let go of your hardware especially a nice once like your Dynacord. I still have my Zed and it's stuffed in the closet. LOL.
Aha! After much digging I have discovered that the mixer has "inserts". These allow (with the right cables) you to pick off signals from individual channels to send to m'track converter such as the A&H ICE.
LOT of faff and a LOT of cables (especially if you want 16 returns!) and still expensive. I would look at the Tascam 20-20 were it me. Dynacord PowerMate 1600-3 | Sound On Sound
That link gives the mixer a pretty good review tho'.
I just figured this out as well. I copy pasted it
"Using as DIRECT OUT
When using the insert socket as a DIRECT OUT (Pre EQ), the stereo phone plug’s tip and ring have to be short circuited, so that the audio signal is not interrupted. If you are using a monaural phone plug instead, you will get a DIRECT OUT with breaker function – the signal flow within the channel is interrupted."
So what would I have to do to use these? How do I use direct outs? What do I connect them to? Can I do it with the uca222?
That extract is just downright confusing. A Direct Out is NOT an insert. D.O's do not disturb the through signal in any way and are often balanced.
To utilize the inserts you will need leads with a TRS jack plug one end (the use of "phono" is also confusing) with tip and ring linked. The other end can be a simple TS jack or whatever is needed to feed the interface.
The link keeps the signal running through the mixer.
Forget the 202/222! They are handy boxes to record TWO ONLY channels from an hi fi rig say but not really up to quality recording.....WHATEVER you do, getting multiple tracks into a PC is going to cost you!
