grimtraveller
If only for a moment.....
If there's even a slight difference then they can't be the same. Even identical twins have differences !Yep, basically the same microphone! Same capsule...same input sensitivity. The only difference between the two is a slight change in frequency response due to the large ball grill of the sm58.
On those American courtroom dramas, this is the part where the smart mouthed lawyer, sorry, attorney shreds your testimony by making heavy weather of "the exact same thing" and "essentially the same thing".Yes, it's the exact same thing. If you unscrew that "ball" off the top of the 58, you have a 57 with some foam (which technically gives it appx. a 1dB variance of frequency response to the 57, but yes, it's essentially the same thing.)
Hmmm, this is interesting.Actually that's not exactly true anymore...
I'm sure (or is that shure?) that the actual gubbins inside are as near identical as they can be but every little change is generally reflected in tiny variations in frequency response, just like the grill and spacing make slight differences.
So...very, very similar, yes. Identical now? No
Somebody, somewhere is peddling innaccurate information. But who ? Who should diannaz actually believe ?
Even if though there be more greater, the present glory is still glorious ?I just have a built in prejudice against 45+ year old gear still trading on past glories!.
Which takes us back to the first quote.Strictly speaking they are different in their response.
Now can you see the inherent problem with your remark in regards to this particular question ? Many questions get asked over and over and over again because so often one will find more than one answer and some of the answers stand directly opposite to others. So how does the newbie or the enquirer determine which answer is the correct one ? Usually, both sides of a debate are pretty forceful in their assertion of their facts and rightness. Using the search function would not have brought diannaz any closer to a satisfactory or definitive answer than the route they eventually took.I swear, someone needs to sticky this question...
Next time you have a question, use the search function on that bar at the top right. We get tired of answering the same question over and over again.
One thing I have noticed though, no one that I've come across ever recommends using a 58 to mic a guitar or bass amp.
I think they're pretty good for that. But kind of lame on a snare.
