Dracon
According to MXL
The V69 stats -
Type: Condenser pressure gradient mic with large 25mm diaphragm capsile
Frequency Range: 20Hz-18kHz
Polar Pattern: Cardioid
Sensitivity: 22mV/Pa
Impedance: 200W
S/N Ratio: 72dB (Ref. 1Pa A-weighted)
Equivalent Noise Level: 22dB (A weighted IEC 268-4)
Max SPL for 0.5% THD: 140dB
Power Requirements: 110/220 Vac, 50-60Hz
Size: 50mm x 190mm
Weight: 1lb
Metal Finish: Black/Gold
The V76t stats -
Type: Condenser pressure gradient mic with a 25mm, 6-micron diaphragm
Frequency Range: 30Hz – 20kHz
Max SPL for 0.5% THD: 122dB
Sensitivity: 38 MV/pa
Output impedance: 200 ohms
Equivalent Noise Level: 22 db (A-weighted IEC 268-4)
Size: 48mm x 195mm
Weight: 525g
Power Requirement: 120/240V 50/60hz
Metal Finish: Silver / Chrome
What I find interesting here is that they do not give a Signal to Noise ration on the V76t while they do on the V69 (as well as the V67G). However, the frequency response graph at their website shows a much smoother graph (with a peak at 15K) for the V69 while the graph of the V76t is not as smooth.
However, what I didn't find at their website was if either, both or neither of these tube mics came with their tubes soldered? Anyone know, would I benefit from say changing the grille & the tubes on a 76t enough to warrant the change?
The V69 stats -
Impedance: 200W
Size: 50mm x 190mm
Weight: 1lb
The V76t stats -
Size: 48mm x 195mm
Weight: 525g
