I know I disagree with the majority on this point, but I've heard John Brandt say something similar and I know I've said it somewhere on HR in the past couple weeks. Putting foam over fiberglass adds dispersion. Not that it helps with taming frequencies or any such, but it helps with flutter echo and should be used if your treatment leaves you some of that. I didn't use any, as it's not usually a problem in small rooms, but built diffusers for the back wall instead of trapping. I've still got 8 of my 2x2 traps left because I did, and am thinking of using them in the living room to get some better sound from the entertainment system.
