R
		Rod Gervais
SpiderM69 said:So my question is, if there's no noticeable difference in the makeup and consistency of the foam, can it still sound different?
Spider,
Suppose I take 2 speakers - 14" - made by the same manufacturer - with no noticable difference in the makeup and consistency of the speaker (and no model markings of any kind) ............ can they sound different?
The fact that 2 materials look and feel and seem exactly the same does not mean they are exactly the same.
In the case of the speakers there could be different wire coils used in the manufacturing - a different wire thickness - a different coil wrap ......... you cannot see or touch that - and thus the speakers (to all of your senses except hearing) are identical.
In the case of the foam, they are made from 2 very different materials - with different chemical properties........... you apparently can't see or touch that - and thus the foam (to all of the senses except hearing) are identical.
Can it be so? Indeed it can..............
Rod
