Lt. Bob
Spread the Daf!
Well that sucked ..... I lost a long ass post .......... sigh ..
Anyways, the RP360 ...... after a couple of weeks I have my sounds fairly dialed in ..... I'll still be tweaking them as I go but mostly level matching and some slight EQ tweaks.
But I find these sounds to be acceptable enough that I can gig without having my playing affected because I'm distracted by them.
The unit is quite easy to edit and understand and it has a lovely USB to 'puter editing program although I find it about as easy to just use the panel on the unit.
I find the cleans pretty decent but a bit sterile .... they don't have that 'bloom' you get with an amp but they'll do.
And the dirty is way better than any of my other modelers ( POD, V-Amp, several rack-mounts, Rocktron, Vox)
There's not many bees at all as long as I watch out for 4k and up on the EQ.
I have 8 presets I've dialed in (each of which can have 3 stomps assigned to the 3 footswitches ).
I can have up to 99 but I find these to be enough for now and most of the time only use about 5 of them.
I have a CLEAN based on a Twin thru a 4x10 tweed bassman cab
The CHORUS is a Twin thru 2x12
I have two crunches and 4 higher gained leads though I might use crunch setting for some rides and higher gained for chords but that's how I labeled them.
The PLEXI sounds are a '68 100 watt Plexi thru a 4x12 cab with V30s.
The CHIEF sounds are based on a Matchless Chieftain thru a 4x12 Rectifier cab.
The '57 Champ is thru a 1x12 and the JUMP Plexi is a '68 Plexi with the channels jumped.
This is just me playing stuff to work on tweaking my presets ..... as soon as I decide I'm done with one I threw down a quick buncha diddling and move on .... it's not what I would call takes .... it's me dicking around and wanting to go to bed!
The recording is the unit direct into the recorder, just like I run it into the A.
