ocnor
Lord Of The Thighs
Here is another clip of a typical rock tone that I would use live. The chain is the same as before : LP > Legacy > PDI-03 > G-Major 2 > interface.
View attachment PDI-03#1.mp3
Cool man, that's pretty damn good for a speaker sim IMO, most of 'em I've heard sound like shit....Good tone dude...Again, I'm pretty impressed with that Palmer box...
Here's a tone from a song I'm working on right now, there's some 'verb on it, but no eq or anything else....
LP > Chupacabra > G12H > e609
Resonance: 0
Presence: 3
Bass: 7
Middle: 5
Treble: 5
Master: 6-7
Gain 2: 2
Gain 1: 4-5
Era: Modern
Bright 2: L
Bright 1: C
Focus: off
Chupacabraverb
That amp really nails the old Van Halen 1 plexi tone. It actually sounds more Marshally than some Marshalls that I've heard.
A DI box with multiple outputs should work. You go in with your instrument, send one output into your amp and one output into your interface.I get the concept and I know you need the Radial or some other box to resend the signal. What are you using to split off a dry signal when you do the initial tracking?
That palmer thing works pretty good. That's probably the best speaker sim I've heard yet.Here is another clip of a typical rock tone that I would use live. The chain is the same as before : LP > Legacy > PDI-03 > G-Major 2 > interface.
Resonance: 0
Presence: 3
Bass: 7
Middle: 5
Treble: 5
Master: 6-7
Gain 2: 2
Gain 1: 4-5
Era: Modern
Bright 2: L
Bright 1: C
Focus: off
Chupacabraverb
Thanks man, I really like it a lot...If I had to pick one of my amps to keep out of the 4 I have, it'd definitely be the one....I'd been wanting a plexi type amp for a long time, & snagged it up while I could...It's not a true plexi (obviously) as it's a Ceriatone, & it's hot-rodded with tons of gain, but in "regular" mode, it does the old Marshall sound pretty good, to me anyway....
Here's another clip from the same song, basically same settings but with the gain bumped up a little & some delay thrown on it.....
ChupaDelay
That's exactly what I do. I get as close to the sound I think I want with a sim so I can have something with sustain and balls to play to, but I only record the direct signal. I then send that direct signal to be re-amped.they just record direct and monitor with an amp sim plug.
Yeah man, I'm very impressed with the sound of that thing, it sounds pretty natural to me...That palmer thing works pretty good. That's probably the best speaker sim I've heard yet.
Thanks dude, these clips were recorded at decent volume, but not wall shaking loudness...I'm still learning how to dial in the amp too believe it or not after all this time...The rhythm clip is pretty low-gain compared to what I usually do, & I like it quite a bit...I know I keep going on & on about this amp, but I swear dude, this is the best amp I've ever played through...The G12H is getting better & better to my ears too, I'm starting to really like that speaker...Those both sound very good to me. Nice fullness but with clarity. These have that thump and roundness and air quality to them though that sims don't really get yet.
But goddamn that delay.
The way I do it Lou is to set up 2 tracks, one for the di, & one for the amp. I'm gonna be recording the extra/amp track eventually anyway, so I have a track template in Reaper that loads both of 'em up....I get the concept and I know you need the Radial or some other box to resend the signal. What are you using to split off a dry signal when you do the initial tracking?
Thanks dude, like I've said a million times, I fuckin' love this amp, to me, it's just so bad-ass, & I'm really glad I snagged this thing up when I did...Yup, I noticed that. Although low gain on that amp is a lot of gain on some others. In any case, I like your lower gain clips a lot. They have good breakup but still retain a lot of note clarity.
Resonance: 0
Presence: 3
Bass: 7
Middle: 5
Treble: 5
Master: 6-7
Gain 2: 2
Gain 1: 4-5
Era: Modern
Bright 2: L
Bright 1: C
Focus: off
Chupacabraverb
Thanks dude, the reason I bought the 609 is simply for a different mic choice dude. I wanted another dynamic mic I could use without having to worry about clipping at high volume (like the condenser mics I have, they can't handle the SPL's), that would sound good on it's own, or blended with another mic...As usual, I consulted with the Gerg, & it came down to the 609 or an i5...Eventually, I'm gonna pick up an i5 too...Just a little different sound dude, kinda like different speakers...Tone sounds awesome man. I expect nothing less from you though. Why did you pick up that e609? Do you prefer it over the 57 for whatever reason? I am sure you have dicussed it prior to this and i apologize if you've explained more than once.
Am i crazy or is that verb/delay effect more noticeable in anyone else's right speaker? IS it me? or was that intended. IS your reverb applied in your DAW. Frig so many questions.
An online buddy is sending me a set of TAD EL34B-STR's for free...Just guessing they should be here around next weekend, so I'm gonna wait until then to mess with the pussy trimmer in the Chupacabra like I mentioned...Dunno if they'll make any difference in the amp's tone or not, we'll see, plus I'll have a backup set of power tubes too....
