Getting better. I aint just saying this, but I liked the clip with my settings better.
I like the brightness. But it is probably a little too bright with my settings.
It reacted about the way I thought it would, which is good for my own info, but it's your sound and we need to get it figured out to where you like it.
The second settings are good too, particularly in the ending section, but I still think it's a little cloudy in the mids. And even though the tone is a little darker in the second section, it still has some harshness in it. It's definitely getting better though.
Here's what I'd suggest you try next:
1) Do a clip with no resonance or presence. Just use the three EQ knobs. I know that on my JVM410 the resonance and presence knobs can kill you fast. It might be the same with the DSL. Live, those knobs are great to suit the room, but I don't use either one of them for close mic recording. 0 and 0. Maybe sometimes a tiny little presence, but never any resonance. The presence on these modern PCB Marshalls can be pretty brutal
2) If you do use the presence, you might be on to something by trading the treble setting for presence, or vice versa. That trick works good on my JMP 2204. Run the treble low, and the presence high, or run no presence and use the treble knob. Both up can be rough with preamp gain.
3) That speaker sounds stiff to me, and I'm betting it isn't broken in well yet. It should sweeten up eventually. In the meantime, try an off-axis mic placement. That could knock some of the brittle edge off your tracks.
4) And I don't suspect this will work with that amp, but try cranking the master vol and running the gain low. This works great on the old 2203/2204 Marshalls. It totally sucks ass on the JVM. I don't think it'll work with the DSL because it's preamp section is similar to the JVM, but give it a shot.
