Maul-the-band compression as a last resort only IMO...  Find out why it needs MBC and fix it before you bother with it.
Lately I've been reaching for a dynamic EQ instead for certain things, like controlling low end build up, room resonances, de-nostriling  on vocals, and even de-essing.  I find they work a lot better than MBC's for similar tasks.  To be honest, I honestly can't find a scenario where I can't accomplish the same thing,
more transparently with a dynamic EQ. I think that might have something to do with the fact that you can tailor the Q-width.  You can't really do that on most MBC's, besides changing the width of each band.  And you can't make one narrower without making at least one adjacent band larger due to only having crossover points.
				Rod Norman said:
			These are all great comments. But it seems the question relates more to why as opposed to when.
Well, the title of the OP is
The Instances Where You DO NOT Use A Compressor.  An
instance is definitely a
when.  In any case,
why is directly related to
when in that you do not arrive at
when without the
why.
				Rod Norman said:
			I'll see if this helps. Compression does two things. It reduces dynamic range, therefore making something sound closer or more present and it focuses frequencies into place in the reduced dynamic range. The first is good if you need something like vocals or the snare to sit in one place in the overall volume and good when mixing to make sure some frequencies are not lost due to comb filtering cancellation. (where several instruments with the same frequency cancel each other out. The new noise cancelling systems work that way by sampling sounds and then broadcasting them back into the room to cancel them out. It's a very frequency focused concept.)
While I think I understand what you're saying in the rest of the above quote, can you please elaborate on what you mean in the bold bits?  Are you talking about the spectral content of the input signal and the focus of the compressor's detector?  What do you mean by "focuses frequencies into place"?
Of course, if there are erroneous resonances or a frequency imbalance in the input signal, the margin of swing between them might be narrowed.  But I don't think that's always the case.  A compressor will be most sensitive to whatever range has the most energy within the input signal, which is why when you feed the side chain an EQ boosting the snot out of 5kHz, you get a de-esser.  I would also wager that it has a lot to do with the specific design of the compressor.  The 1176 was famed for retaining the top end in a recording because most compressors, when hit hard, dull the tops.  Good designs tend to not suffer from that ailment.  Is that what you're talking about?
And that's not really comb filtering.  Comb filtering results, for instance, when two microphones on the same source are shifted from each other by distance, and therefore by time (point of origin and speed of sound staying a constant) or when a signal is delayed and added to itself, causing modulation interferences.  It is also the basis of modulation effects like chorus and phasing.  That is why I am having trouble understanding why you have brought this up in a discussion around compression, which is an amplitude-domain process.
Please could you also explain the "new noise canceling systems" and link me to an example of this technique or technology?
				Rod Norman said:
			So, I use no compression on anything that I want to balance with high or low volumes in the mix; basically everything.
I'm sorry - and I'm really not trying to be funny here - but this statement confuses me as well.  Are you saying that you don't use compression on anything?  Can you please clarify a little more?
				Rod Norman said:
			But many vocalists do NOT have the best mic technique and need some compression during recording to keep them present while reducing clipping if they get too close or too loud. This method of compressing before mixing allows you to get what is known as a smooth volume level with whispers as loud as shouts. The snare and the bass drum in pop music sometimes needs to be tight in the volume range, so I compress them during recording. Everything else is allowed to breath so that the drums sound more human. Even if it is jazz and the drummer might feather the bass drum or snare, those ghost notes don't get lost.
Nebulous once again but I think I see what you're saying.  You're talking about how dynamic sources sometimes need compression during tracking, right?  I don't have a lot of outboard but because I have a pretty monster studio machine I can use a very low buffer and apply my UAD plugins at the track level if I or the performer wants to hear compression during tracking.  Same with reverb.  I use the Control Room Mixer in Cubase to make cue mixes and it works like a dream so all of my processing is truly done ITB at the moment.  However, I do miss having a compressor to use on vocals (I sold all my compressors begrudgingly in a studio upgrade), but I think that'll be my next purchase.  I've been looking at an FMR RNC.  That's all I'll need, really.  I don't generally compress individual drums any more but now and then I'll compress the kick to combat flabbiness.  I way prefer to use a dedicated drum bus compressor like an 1776 or a 160VU emulation, or even Bootsy's Thrillseeker LA on the drum bus, which I can also do during tracking.
				Rod Norman said:
			Everything else has no compression either during recording or during the mix.
				Rod Norman said:
			During mastering, I will burn a cd and see what it sounds like compared to similar other groups in the finished state listening carefulky for frequencies that seem to make the finals pop. If my masters need some compression, I will run them through a multiband compressor and check the presets first. Sometimes there is a perfect one. (ignore the names like rock or jazz) If I feel it needs tweaking, I will do that. I will then again check a cd against my gold standard cd. I might do that again over several days, letting my ears rest between each session. Then I try it out on many different systems to see if I got it right.
 I hope that helps.
 NewYorkRod
Sorry, please can you explain the bolded bits again?  You're jumping around from frequencies to compression and I'm not really following.
I personally wouldn't look to a MBC as my first go-to processor if I feel the mix needs some compression.  I would simply compress it with a normal wideband, possibly something like a Manley-Vari MU, an SSL 384, or a Tube Tech CL1B.There might be a time where the low end might need a little compressing on it's own or a strident frequency here or there, but in those case I would use maybe one or two bands.  But then again, I don't use MBC's too often.  And presets?  I don't think there could be anything
more destructive to a mix than a preset on a multiband compressor.
And yes, referencing is a must with any recording (even though I hate it because it's the moment of truth!).
Cheers
