Most people miss the point on this.
I have used this quite successfully many times.
It works best on something like percussion that you want panned to one side.
In my case- I've used it on a Floor tom that came in occasionally and was panned to one side, and was meant to be a little louder than normal. More of an effect than a typical tom fill.
Every time the hit came, the left side of the mix shot up- compressors didn't know what to do with it.
Enter the Haas solution. Printing a copy to the right side, evened out
the balance, and made the tom louder so that we could lower the volume on the left side. Then add a few ms of delay the right Tom and the left tom again appeared to come from the left.
Plus, now the levels showed a much more balanced level.
You can test in mono to see the comb effect. By changing the delay and level of the right tom, you can get something quite acceptable.
I wouldn't use this on a constant playing instrument. Only on the occasional, out of ordinary part, that messes with your overall balance.
