gecko zzed
Grumpy Mod
Highly competent in every respect. Exceedingly well done!
My favorite Cheap Trick song, that is just one fun song. I prefer the vocals up a bit. Other than that, not bad for knocking one out.
Thanks a lot miro. Yeah it's sometimes difficult to track real loud because feedback can be a problem if you don't want it and it is ear damagingly loud, but like you I wear my drumming iso cans to protect the ears and I don't mind feedback.Sounds real good....and even though it's not a pure nockoff, your take on the songs works very well.
Yeah....I agree....loud guitars/amps do something that sims and small wattage amps don't....they MOVE the speaker, and move the air, and that moves the sound more around the room and then it all moves into mic with a different energy than a 5W amp going fizzzzzzz or whatever.
I messed around with attenuators and very low wattage amps for awhile, and yeah, you can get nice tones with them....but they never sound quite like an amp played LOUD!
These days I tend to record most guitar tracks at louder levels. I like it that way much better, and I can get away with it at my place, and I've got headphones on so it's not killing my ears....I mean, just 'cuz you track loud doesn't mean you have to listen to it at that level.
Anyway....nice job on the tune. I always liked that Cheap Trick song.
Thanks Ray. Got any recordings of that?Just COOOL.
I used to play this in a Power Pop band in the early 80's.
It's a terrific song.
We didn't sound this good because we didn't play LOUDly.
I really enjoyed the wah additions.
Good stuff.
I think there is probably some truth to the idea. Especially with a band like The Who. Pete's big ol guitar sound was a big part of their sound. When he switched to acoustics to help his ears it sure didn't sound right. I don't know all the technical electrical reasons why a tube amp just tends to sound better loud, but they usually do.Not sure if I'm repeating this correctly but Pete Townsend said that when guitars and bass are played at extremely loud levels they produce more harmonics, more layers of notes are floating around the original note you play, therefore there is more music/notes coming out (in fact)
The Who asked him to go on tour like around 1989. He said sure as long as we don't go over 100db. They all said sure no problem. He said you guys don't get it, at that level, half the sound will be missing. So he brought in horns, backup singers, etc etc. to fill in for the lack of volume and Harmonics. Interesting perspective if its true.
Thanks Johnny. What do you mean by spread the rhythms more evenly? They're 100% L and R. The left one does cut a little more though. Is that what you're talking about?Nice job, Greg. I think you've upped your game a little here. I'd prefer the rhythms spread more evenly, but that's no biggie. Love the backing vocals at the end, but they seemed to drown the lead vocal a little when they came in double time. I've never heard the original, so can't compare. Awesome stuff!
Thank you sir.Highly competent in every respect. Exceedingly well done!
Ditto.
Solid job Greg! The drums sound a little plastic/lifeless to my ears and the verse vocals (because of lack of accompaniment) a bit dry. For funsies though this is good.
I used a small muffle ring on it for this tune just to try it out, and I won't be doing that again.
The rhythm guitars are all the way panned and the vocals are dead center. The little back up vocals are spread about 50%. The right rhythm is a little "dirtier" though. They sound close enough to me, but I'm pretty used to it.Listening on my headphones it sounds like the right rhythm is not quite hard-panned. I listened again just now to check and it sounds the same, but the vocal sounds dead centre. My ears are a bit funny after a cold last week, but it's my left that is problematic. Maybe it's just the different frequencies compared to the left that's fooling me. It's not an issue, really, I just noticed it.
Yeah the plastic rings. They suck, and I know it, I've always known it, but I decided to give it a go anyway. I've had this set under my couch for like 7 years and just fished them out. Lol. I used a small one on the snare. The toms were left alone.You mean the plastic rings?
Yeah, they can help the sound sometimes....or muck it up.
I keep a bunch on hand in just about every size for all the different drums....but most times they end up not getting used.
I'm sure you've tried the small moon gell pads....what do you think of them?
They're handy when you're in a pinch... when there's the odd ring or whatever, and tuning doesn't quite work or it's in the middle of a tracking session, and you can place them in just the one spot as opposed to using the rings.
Great choice of song to cover. Great version. (I expect nothing less) Everything sounds great to me here. The guitars are especially sweet. All good!
Top Banana!
Thanks a lot for checking it out. Missing the kick, huh? That's probably a first for one of my mixes. I'm not having that issue on my setups. How do I EQ the kick.....I usually do a tiny narrow sliver of a mild boost wherever I like the thump. Like usually around 45-60hz. Somewhere way down there is some real thump. But I just barely put any in, like maybe 1-2db of boost. Then I'll usually carve out a little scoop somewhere between 100-500. Sometimes two more focused cuts in that range to tighten it up. There's a lot of boxy muck in that range with my kick drum. Maybe that frequency range works for others, not mine. I hate what's in a kick drum from around 100-200hz. That's just me. Then I'll do a super wide but not too aggressive boost in the high end to bring out the attack without it sounding too focused and clicky. I usually use plastic beaters, but I've switched back to felt and I'm having to EQ my kick a little differently than usual.Tight!Love your take on this. Sweet dripping molten tone. You really do a great job finding a place for everything. I'm missing the kick a little, how do you EQ it? I enjoyed the description of your lead guitar process too. You're a drummer first, right? I'm a guitar player and know notes, scales, etc., but I rarely use it. I still prefer finding what sounds good by hunting for it.
Great job, but I think I need new computer speakers now.
Wow, thanks Trip. That's high praise. You usually find every little crackle and pop in any mix, so I'm extremely humbled that you found nothing to point out.I loved this. I thought everything was great. Especially great energy. Everything sounded awesome. Not even any nits. Sounded perfect to me.
Haha, a sax! I can't imagine this song with a sax in it.No recordings Geg. You wouldn't have liked it though as, on bass, I was the only tube head in the band and we had a sax playing in the song too - don't know where anymore - the why is simply because we had a sax player.
Wow, that's awesome. Thanks WS. Your wife must be pretty special if you made her listen to one of my albums and she didn't immediately file for divorce.Dude...you own this shit!
Imagine the quandary I faced earlier today as I made the mistake of talking music with my wife: "So there's this guy, Greg, you know, we listened to his CD when we drove to Springfield. Anyway, he's a killer drummer, and I wanna go to his house in Katy, TX and see how he tracks guitars."
It didn't make sense to her, and it almost doesn't to me, but like I said: you own this shit. That's a killer sound.
The funny thing is that I just bought this CD about a week ago. And this is by far my favorite track. If only they did it as well you did...
I agree with everything that's already been said. I like the vocal...way more attitude than the original which was a bit too sweet sounding for my taste. Great energy level and tempo. As far the vocal needing to come up....nah, it sounds perfectly mixed in the context of the tune to me. It's a high energy rock tune not a ballad.
I really want to give you props in the guitar tone. The guitars just flat out rock in every way and the wah sound is killer ...as good as I've ever heard on any recording
Good job brother!
Thanks dude. Yup, all me.Greg, sounds great, love the drums. It's all you, right, all instruments and vocals? How do you start, ie, lay down a scratch track with a click, or just drums/no click?
Ha, thanks dude.Greg's all right. Sounds great man.
