TelePaul
J to the R O C
I am. I find it so hard to play straight notes. I actually have to concentrate!![]()
Ok. For a minute there I was like 'fuck!'
Oh my god you got it wrong!!!! HAHAHAHA!
I'll give it a listen when I get home. I'm just shutting up for the night.Here is an MP3 :
It does seem to get a little worse as I go up the neck. Any advice from this?![]()
Interestingly, the bridge was on backwards. Must have been something I did a long time ago and didn't put right or something that's always been that way.
The flat face of the saddles was facing outward along with the adjustment screws. I thought it was a little odd so I searched for some close-ups of Les Paul bridges and I was right, it was on backwards.
I've corrected that little error now but it sure hasn't cured the problem though!![]()
i don't think that's a problem, the saddles on tune-o-matics can be reversed and often are, to accomodate intonation.
will you already try a new string?! The suspense is killing us? !![]()
Well, I threw caution to the wind and restrung that string. I used the old 'D' string from my previous set since I've gone up quite a step in string diameter (although have compensated by tuning two full steps down!).
It seems to be fine now, but it is a wound string rather than the unwound G I had.
If I offer the two strings up against each other they look identical in diameter, but I'm not sure.
Any ideas how to proceed? I'd like to try and get this guitar to accept that G string to save me buying two sets each time I restring
Does anyone think it's worth buying the same set again to see if it's just a bad string or is the likelyhood slim to none?
No offense meant but this is the first thing I would have done before anything else.
In which case it is almost certainly the saddle slot or a bad string. Try a new string of the gauge you want and if the problem returns you need to look at the saddle slot. There isn't enough change in tension to effect the neck relief with just that string as a difference. Also it is incredibly rare to have a bad unwound string so I'd suspect the saddle slot. Glad your getting somewhere with it.
