M
MadStrum!
From reading these posts I've got the impression that it's quite buggy and not really worth the $$...
Still wondering whether to get it...
Pier.
Pier.
MadStrum! said:From reading these posts I've got the impression that it's quite buggy and not really worth the $$...
Pier.
Wow! Can I quote you on that?Sklathill said:Honestly, very refreshing to go home to Sonar 3 after working with DP3 on the Mac...
Q.
Very true!Qwerty said:Either way - it's supposed to be about the music. A great song will still sound great irregardless of which version it is recorded in
moskus said:Wow! Can I quote you on that?![]()
Where do you hear these roumors?MadStrum! said:I heard that DR008 , which i use for almost every song...doesn't work well/does not work at all in Sonar 3...
Pier.
Qwerty said:Hey if you are referring to anything that I have posted, don't worry - I really am splitting hairs. I find it much more stable and efficient than 2.2 XL.
All the other comments concerning the quality of the included plugins in the PE version are correct IMHO and I would not hesitate to recommend the upgrade to you if you are in a position to afford it. [/i]
And that system is stable?wfaraoni said:I even loaded it on my old 300 mhz at work learning laptop with 64 meg ram XP and it has performed well. Even Better than 2.2 did. I have not found any bugs YET! But I have not spent much time using it either.
moskus said:And that system is stable?
I have a 300 MHz laptop I don't know what to do with. Thanks for the tip! WinXP, here it comes...![]()
Okay, I'll install WinXP on my 300 MHz laptop now. I always thought that it would run best on Win98SE, so I didn't try it when I formated it this summer.wfaraoni said:I have an unusual laptop and the documentation says it runs faster with 64m ram than 128.???/
