My mix notes and Thoughts
Hi guys. Here I leave some of my thoughts on my mix and how I worked.
Hope my english is good enough
ntro
The piano went through the SSLChannel using eq and compression and after that a delay using the Haas effect on the piano
The vocal verse goes through first of all an dresser and after that a CLA-2A. And after that I use eq and some multibandcompression from the C6. I also send the vocal to a vintage delay. Vintage delay is when the delay frpn the vocal is send to itself so the delay have delay. I use eq after the delay to create an interesting sound cause the delay will change every time it passes the delay.
pre chorus
All the vocal except the verse is send to busses so I could organize them.
The pre chorus vocals is almost the same as the verse but no C6 and an SSLChannel instead. And I also send them to a reverb socially for the pre chorus and the chorus. I Use Revibe for my reverb.
Chorus
In the chorus I really wanted to have a energy change and I think the producer wanted it so. The way I did it was to let the beat go through the Scheps 73 and use the the drive to get some Neve distorsion on the beat and in the same time open up the top. This is automated and is not on the first verse. It gave it the feeling of energy in the chorus.
The vocal in the chorus have delay and reverb specially for the chorus. And I like to spread the vocal in the chorus.
Verse 2
Automated the kick here to give it an energy drop to have more energy for the next chorus. Other than that I did not so much. Picked out some instruments different than in the first verse.
bridge
Picked out the low vocals in this a bit more så the bridge would separate it sound from the rest
In the slow part I made the vocal thin to fit the low energy ind delicate piano.
In the last chorus I raised the drum package to get out that last energy
Other teqniques I used
Parallell compression on the drums. Use the CLA-76 with two different settings
Puigtech on the bass to get that nice low end sound from it.
