Well, Just for the sake of argument I'm willing to provide whatever to show you that amplitube reacts the same way. The guy just said, "the amp sim makes all pickups sound the same" It doesn't. These are not amp sims that line 6 has in their spiders. These things are a lot more
advanced than you are thinking they are.
I have real amps, they react the same way. The exact same way.
Pod farm is a different situation from amplitube. I believe
pod farm is like you said, simply an input knob.
Amplitube does not react that way. It reacts exactly like the real amp does. I can go to my 6505 or the 5150 on
the amplitube and the tube screamer does the same thing, it reacts the same way, it does matter which pickups you use as well.
The TS is adding more than signal strength which is exactly what I said. That is why I asked which is preferred. Because to make amplitube sound good, you have to have a strong input signal. You have to pretty much turn the pre amp up to almost clipping (not in the daw, in amplitube) or you can keep the pre amp down and use a tube screamer, a real one, or a digital one. They both will make the signal go up in amplitube.
Why would I skip the amp sim and rock my tube amp? For what? I'm simply writing songs I'm not micing up my amp for that I use these amp sims for writing songs. When I record the real thing, I use the real thing if I want to. Sometimes I don't. For example, I've used a real 5150 on the same song with a fender twin amp sim.
This SHOULD PUT AN END to the argument. If you click this video and watch it, you will see exactly what I've been saying the entire time. And maybe you'll get it. This is from Andrew Wade, he has recorded a lot of popular metal bands. He used amplitube about 50% of the time compared to the real amp. He's going to show you in this video him doing exactly that. And he's going to show you why the input signal matters, and he's going to show you what the two sound like side by side. If you watch this and still don't get it, I cannot explain it anymore. I don't have any more words. I guess you'd just have to see it if you haven't experienced it.
And don't change my words. I didn't say amplitube sim sounds better than my real amp with tubes in it. But on a recording, it's VERY close. As you will see in this video.
https://www.youtube.com/watch?v=48SN0I49EjU
