Yes, But the hookup's just looked confusing after a while. I tried plugging in a guitar, and a reel to reel machine. I also tried outputting to a reel to reel. With headphones plugged in I got zero signals. and all the faders were up and the channels turned on. Could a fuse have blown somewhere?
Yes, a fuse could be blown but a thousand other things could also be the issue including user error as you've essentially admitted you don't have an competent operational grasp on the usage of the mixer.
So you're going to need to sit down and patiently read through the manual as many times as necessary to get a grasp on the signal flow logistics of the board. Turning faders up and turning channels on, on a complicated board is often only part of the process. You also have to know how the monitoring system works as its possible to have turned and switched everything the right way except that you might be monitoring an aux system on the headphones instead of a program mix. So you really need to 100% rule out user error before you start thinking an evil fuse is the party poopper here.
Some other things to consider;
You bought the mixer without the power supply umbilical cord. So this means you bought the mixer without testing it or having the seller demonstrate that it worked. This is not good. What if anything did the seller have to say about the mixer's working condition prior to you handing over your money? M-520s in good working condition often sell for triple or more of you said you paid for it. So to me, that's a bit of a red flag as there's usually a technical reason behind a low price like that. I know you were working on a tight budget to get the mixer but you've got to know the pitfalls which I tried to warn you about in the other thread you started.
So first thing to get under your belt is knowing how to operate the mixer so that you'll know if you've pressed all the right buttons and still aren't getting sound, you can then suspect and troubleshoot technical issues.
Also, one other topic to cover with the M-520 is
Jumpers. The 520 used them on the rear panel between the ACCESS SEND/RECEIVE RCA jacks. If those are not in place, no sound can pass through the channels. Are they there? If yes, then we can look at other things like program buss assignment buttons, buss faders and so on. If they're not there, then you'll need to get some short RCA to RCA phono plug cables and patch that in so the signal can pass through the channel(s).
Cheers!
