RICK FITZPATRICK
Howdy Guys, well I didn't mean to stir up a hornets nest, but at least things were set straight both ways. Thanks Steve for the clarification. I feel better now
This is what threw me. Bruce wrote:
" The control room patchbay's chassis was then run straight to earth ground outside." NOT THE XLR CHASSI's!. GOT CHA!
I know it is VERY hard to describe this stuff. Anyway this is all clear now. But I'm going to RESTATE it so I know it is correct, OK?
Starting at a MIC...The XLR.Cable Shields are NOT connected to pin 1. They are terminated to NOTHING, is that correct? At the other end of the Mic cable XLR, the shield IS soldered to Pin 1. Correct?
At the Studio XLR PATCH PANEL, on the BACK side, ALL Pin 1's are tied together by a common buss wire, as well as EACH shield of a balanced pair whether it be individual or multicore, is soldered to its own respective XLR pin 1. Correct?
Also, the master foil shield of a multicore cable is solered or tied to this common buss across all Pin 1's. Correct?
This multicore or single sets of balanced cables, then goes to the backside of a CONTROL ROOM XLR patch panel where they are soldered in the exact same manner as the Studio Patch panel. Correct? Which means, UNLESS, a balanced cable is connected from the Control Room XLR Panel to the mixer. there is NO GROUND connection to any shield at any point. Correct? But if ONE cable is connected between the mixer and the control room Patch panel, now you have GROUND at ALL panel XLR connectors PIN 1? Correct?
AT the mixer.... All XLR CABLE connectors (pin 1) are soldered to the shield of each balanced pair of a Multicore or individual cables which extend to a Control room XLR patchbay. At this end, the cable XLR connectors are wire identical as at the Mixer XLR connector. However, in a multicore, with fans at each end, WHAT happens to the foil sheild at each end? Nothing? it is just terminated?
Ok, now for the panel AND XLR CHASSI connections. At the studio Patch panel, A buss wire is soldered across ALL XLR CHASSI PIN (G)'s, correct. In the event of more than ONE panel, a buss wire is also soldered between each SET of Pin (G) buss's, correct?
Now, since the XLR chassi's are phyisicaly mounted to a steel panel, Pin(G)'s are already connected to the panel. Now it is only a matter of soldering a wire, from the studio panel Pin (G) buss, to a Pin (G) buss at the control room panels. From there, a wire must now go to a power supply ground. Correct?
To ABSOLUTELY make this clear, at NO POINT other than Mixer PIN 1 connections, do any XLR connector shields obtain audio ground. Correct?
I sure the heck hope so.
BUT now, this also brings up another quagmire, which is EXACTLY what my question was about in the "grounding" thread from hell.
To refresh your memory, the question was in regards to a SECOND grounding point(ROD) when a sub-panel is added to a residential supply panel. I need no explaination OTHER than this.
IF, the NEUTRAL side of the supply is grounded, whether by rod or water pipe, and by code, your added sub panel MUST have its own grounding rod IF it is beyound say 60',
and both the supply ground, and sub panel ground must be connected TOGETHER, does this in effect make a complete circuit for ground? That was the question. Whether both grounding points had to be tied together at the sub panel grounding buss. No one ever answered me. And IF it does, I was told this makes for ground differentials that show up in audio. Thats all I wanted to verify. Ok, I'm done.
fitZ
fitZ
