RSM2, RSM3, RSM4, RSM5, Apex 205 & Coles 4038
Today I had a chance to do a quick voice test on a number of different ribbon mics. On hand were
the Nady RSM2, RSM3, RSM4, RSM5, Apex 205 and Coles 4038.
With the exception of the 4038 which remained stock, all mics were modified with a Lundahl transformer, 1.8 micron ribbon, acoustical damping and a single layer grille. In the case of the RSM3, achieving a single layer grille required cutting away the horizontal bands and installing a new stainless steel grille.
The quick take away - each of these modified ribbon mics is in the same quality league as the 4038, a mic known for its smooth and extended frequency response.
Here's some similarities and differences between them.
RSM3 (oblong "lollipop") and RSM5 ( Royer-look) - both of these mics use a nearly identical motor with a 35mm x 5mm ribbon offset toward the back of the magnet structure as the mic is faced from the front. This asymmetrical placement of the ribbon creates non-matched lobes and a brighter frequency response on the front side (recessed ribbon side). Note that the ribbon asymmetry is the opposite of that used in a Royer mic (probably done to avoid an obvious patent infringement). Once modified with greater open-area grilles the RSM3 and RSM5 are essentially identical. While not optimum for M-S or Blumlein work, the offset ribbon design does offer a chance to experiment with two slightly different high frequency response curves. As a side note, the stock RSM3 grille bands create such complex high frequency interference patterns it is hard to describe their effect - definitely a HF coloration that tends to render "S" and "F" sounds a bit smeary.
RSM4 (round "lollipop") - While this mic also uses a 35mm x 5mm ribbon, it is placed nearly symmetrically in the gap. Yeah, I know - the RSM4 is spec'd as 45mm, but the magnet lengths are 35mm and this measurement is how the RSM3 and RSM5 are specified as 35mm ribbon lengths. The overall sound of the RSM4 is quite similar to the slightly darker "ribbon forward" (back) side of the RSM3 and RSM5. The near-symmetrical placement of the ribbon in this mic makes it a better choice for M-S or Blumlein recording.
RSM2 (large yoked body) and Apex 205 (small blue body) - These 50mm x 5mm ribbon mics tends to have a bit lower resonant tuning than the mics listed above. In addition, the vertical off-axis response falls off quicker in these longer ribbon mics when compared to the 35mm ribbon length mics. Both mics feature symmetrical placement of the ribbon in the gap making them the best performers for M-S or Blumlein recording. Of these two, the Apex 205 has clearly lower headbasket-induced mechanical resonance.
Some thoughts on a comparison with the Coles 4038.
The 4038 is about 3.5 dB more sensitive than the mics above and has outstanding AC hum field rejection. The RSM2, RSM4 and Apex 205 have wiring that can be physically tweaked to improve hum cancellation but still don't equal the 4038 in this regard.
All of the modified Chinese ribbon mics have a very smooth midrange and very adequate top end. In no case was the energy of high frequency "S" and "F" sounds attenuated relative to the Coles. In fact, I would argue that all of the modified Chinese ribbon mics had more accurate HF transient response and a "tighter" presentation of "S" and "F" sounds than the Coles. I believe this may be due to the difference between the minimalist approach I take regarding ribbon damping and motor housing when compared to the Coles which includes ribbon damping screens, low frequency baffles, perforated high frequency reflectors and a perforated metal case. All of these design features of the 4038 were arrived at to solve certain problems, but they do impart subtle, audible artifacts.
These Chinese ribbon mics have striking visual differences. But once the acoustical artifacts of the different grilles and bodies are minimized, state-of-the-art transformers are swapped in and lower mass ribbons (the Coles is a 0.6 micron, 1" ribbon) are installed and tuned similarly, all of these mics sound quite similar - and very good indeed, like real recording instruments in the class of the 4038.
