J
jaybriggs84
Thought I'd show you guys this, it's the Stupid Deal of the Day
http://www.musiciansfriend.com/stupid
You'll be happy with the RSM-5. It should have a nice character.
Cool....I went ahead and ordered one....I see they are sold out now....maybe I got the last one....![]()
Look out for the sagging ribbons! In the past three days I've repaired and upgraded five Chinese ribbon mics - all of them have had ribbons sagging out of the magnetic gap. Here's some pix:
http://www.hometracked.com/2007/08/28/ribbon-mic-sag-and-repair/
I used to think only 30% of these mics had ribbon tension problems, with this week's batch I'm thinking its a lot higher.
That'll be easy enough to set up.The first thing to do with a Chinese ribbon mic is to listen in headphones and test for a slack ribbon.
Just rock the mic mic back and forth slowly - bring one face of the mic parallel to the floor, return upright and bring it back down parallel to the floor on the other side. Do this a couple of times. The idea is to allow gravity to pull the ribbon. In a mic with a severely slack ribbon, you will hear a sudden "clang" or "clunk" as the ribbon (which is often bent into an "U" or "S" shape because it so slack - see pictures at the link I posted above) suddenly shifts position.
If you can rock the mic back and forth slowly and don't hear a sudden metallic sound, the ribbon is not excessively loose and probably has adequate tension.
If a mic with a very slack ribbon is placed in front of a sound source for recording the output will be very low and probably distorted at high levels.
