MOTUs as stand alone devices?
  • Thread starter Thread starter Cazzbar
xstatic said:
As for the insert cables on the console, hopefully you have your HD24 setup for -10db unbalanced inputs rather than +4db balance inputs because you are most likely using -10db sends if tapping the insert jacks. Especially on a cheaper console. It should be an easy thing to check on the HD though to keep all of your levels proper.
Good point, I remember looking when I first had the mixer, the output spec for the Inserts state "0dB (0.775 V)" kinda in-between the consumer and pro levels? If the HD24 is set to receive at +4dBu and I've set the gains on the mixer channels to peak at 0dBVU.. then I'm sending a slightly weaker signal than HD24 expects? can I change this? just looked at the online manual for the HD24 and it's not obvious, Cheers.
