I've an HD24 which I'm currently hooking up to an analogue mixer to record the band live in a rented room, but this uses about a ton of Insert cables so in the future it would be nice to utilise the 24 channels of ADAT I/O on the HD24 for nice and neat connections.
I'm about to upgrade my soundcard for my home PC, used for personal recordings and single track band overdubs, and was looking at the MOTU 828mkII. (maybe overkill for my needs but I've a large credit note)
I was interested to read the 828 has ADAT I/O and can function as a stand alone mixer, this got me thinking I could use it as a front end for my HD24, but it hasn't quite got the number of inputs I would require (8 Mic and 8 Instrument) so I would also have to expand the 828 with a MOTU 8Pre as recommended.
All looking good but as I would be recording about 16 tracks simultaneously, this is where my brain starts to hurt.
If I link the 8Pre to the 828 using optical ADAT, then although the 828 can now 'see' the 8Pre it only has 8 tracks of ADAT out.
I guess I could link the 8Pre and the 828 separately to my HD24 using ADAT, but then I need to create a separate monitor mix from the two interfaces. Can the 8Pre function as a standalone monitor mixer like the 828? If so I could pass this mix onto the 828 as another standard input, or use my headphone amp as mini mixer to link them up.
Then I looked at the MOTU 2408 Mk3 which has 24 channels of ADAT I/O, a perfect match for my HD24. I Could link an 8Pre to that and easily have 16 channels of ADAT going to my HD24, but can the 2408 function as a stand alone mixer so I could create a monitor mix? Reading the documentation it only suggests this is possible using a PC.
Any help on this (and any better solutions for my needs!) would be appreciated
(I'm already starting to think that bringing a laptop to the recording session rather than using the HD24 would be a better solution, but would also like a reliable live solution for this as well in the future, and would like to exclude wintel gear for obvious reasons)
Cheers
Cheers
