theD1CKENS
*insert clever title here
As Lt. Bob says, speaker cables don't need to be shielded because they are carrying high voltage (relative to any hum that may get in) that won't be getting amplified. And driving speaker loads through shielded cables can be bad for amps.
For hum to be audible it has to get into a low level signal and be amplified.
To be clear, sometimes it's necessary to have my head close by, while the cab is on the other side of the room/stage, in which case I use any random 20' cable that happens to be lying around. Usually an instrument cable.
If an instrument cable is different from a speaker cable, I was unaware of it. Is that bad for gear?
